Power under a load
paul MI
09-13-2002 16:50:10
I just finished repairing the valve train and replacing all the rings on my 47'8n. Everything seems to be ok,except that there seems to be a lack of power und a load.I know that these tractors only have 27 or so horsepower on a good day,but it seemslike they should be able to pull it's self up a slight grade in 4th gear and not loose too much speed. Any info is appreciated. ps)all the valves are adjusted properly and the points are at 0.015.
Dave OH
09-13-2002 17:16:21
 Re: power under a load in reply to paul MI, 09-13-2002 16:50:10
Although 4th. gear is a drive gear, not a work gear it should go up a slight hill under enough throttle. If you are having a problem under load in all gears it is probably a Govoner problem. But then you will also hear (ignition and fuel) problems. You will have to check as you go along.
Dave OH
