Crankshaft,to grind or not to grind
russ
09-17-2002 19:26:14
i have a 2n and the main bearing journals are fine but the connecting rod journals have some wear in the middle but the outsides of the journal are within tolerances.should i still get it ground or not?thanks for any reply
TimK
09-18-2002 07:14:19
 Re: crankshaft,to grind or not to grind in reply to russ, 09-17-2002 19:26:14
Any good mechanic will tell you to bring things back to standard tolerances where possible, and don't risk chances. Your concerns are well founded. Grind it, and get it back to standard tolerances. For low rpm engines, there are oversize bearings available all the way up to .060" as I recall, which work out OK. Your engine will last longer if the job is done right. My $.02
Big Mike
09-18-2002 02:12:07
I like Dell are not a mind reader so here goes...Ifin its a stock crank and only needs a .010 undergrind to make things perfect I would go that route...IFFIN its allready .030 under I would consider polishing it and runnin it
bg
09-17-2002 19:45:14
I would consult a good machine shop. I hate to put new bearings on worn journals, however slight the wear. Plastigage is the presiding judge.
