NAA Regulator Wiring
Ollie Fuller
09-18-2002 15:10:29
Before I burn up a regulator. Which terminal of the regulator does the ammeter lead connect. One of three, ground, armature, or field. I would think it is the armature.
Dell (WA)
09-18-2002 16:20:07
 Re: NAA Regulator Wiring in reply to Ollie Fuller, 09-18-2002 15:10:29
Ollie..... ....Conventional wisdom sez: use you ammeter to measure electrons going into and outta the battery (ie...charge or discharge).
My NAA electrical diagram shows 4-connections to the NAA voltage regulator.
1) V/R ground to generator case ground, sometimes it is just under the screw holding the V/R inplace. Sometimes you don't recognize it, but it is very essentual in rusty old tractors to get the 6 volt generator to charge correctly. 2) V/R field to generator case field
3) V/R ARM to Generator ARM output stud
4) V/R BATT thru ammeter to BIG starter solenoid BATT stud. This is the one you want your ammeter in.
Don't forget to "polarize" your new voltage regulator by briefly shorting the BATT and ARM terminals, just a spark is all you need. Do it without the engine running. Remember, NAA's were originally BATTERY POSITIVE GROUND..... .Dell
