Another ?
Norman
09-18-2002 17:06:50
On my 8N, there is a pipe coming out of the hydralic pump where you would check the pump pressure. It has two valves on it and emties into the top of the transmission thru a bolt hole. Does anybody know the reason for this?
Thanks for the help
Norman
bg
09-18-2002 18:02:12
 Re: another ? in reply to Norman, 09-18-2002 17:06:50
The scotch-yoke pump doesn't need bleeding as it sits in the reservoir surrounded by fluid and is constantly pumping when the PTO is engaged. The plumbing is someone's home-made auxiliary hydraulic system, probably for a front-end loader or somethingf like that.
AL
09-18-2002 17:10:20
It might be to bled the air back into the reservior to prime the pump.
