Type of thinner for TISCO med. gray paint?
Pokey
09-18-2002 17:55:16
What are you using for a thinner for the Tisco brand of paint? E_mailed the company but got no response. The can says some number 400 something but no name or brand of thinner. Checked archives with no luck. Thanks, Pokey Do not want get this far into it and get CURDS!!
don b
09-21-2002 08:46:32
 Re: Type of thinner for TISCO med. gray paint? in reply to Pokey, 09-18-2002 17:55:16
Pokey, I believe xylene will work fine.It is sorta hot so it won't take much. don
Jim Ag
09-18-2002 20:09:46
TISCO has its own thinner. You may have the have your retailer order you some; Thinner: TPS 46 QT $ 8.60 Thinner TPS 46 GAL $ 13.44 Thinner TPS 46 5GAL $ 58.65 Hardner: TP 12 $ 7.53
Good luck on your paint job.
Jim Ag
Pokey
09-19-2002 15:48:29
 Re: Re: Type of thinner for TISCO med. gray paint? in reply to Jim Ag, 09-18-2002 20:09:46
How or where do I locate a retailer in PA? Have had no luck on the inernet. Thanks, Pokey
Jim Ag
09-19-2002 20:20:30
 Re: Re: Re: Type of thinner for TISCO med. gray paint? in reply to Pokey, 09-19-2002 15:48:29
Pokey,
Call 1-800-338-0145 and ask for their nearest dealer to your home town.
Good luck.
Jim Ag from Alabama
Ole
09-18-2002 18:10:53
Pokey
I use VM&P Naphtha. I just finished painting my second 8N in the last 4 months and they both turned out great. I used TISCO med gray on both. Be sure to use the tisco hardener.
Bill Stuckert
09-20-2002 11:41:38
 Re: Re: Type of thinner for TISCO med. gray paint? in reply to Ole, 09-18-2002 18:10:53
Tisco offers the thinner - TPS46-qt (quart) or TPS46-gal (gallon) and the hardner TP12 - all available through a TISCO dealer...
Thanks!
PS - a naptha based thinner will also work.
