Dust Cover ??
ONT RICK
09-19-2002 07:02:36
I need some advise re dust cover I have late model 8n with side dist I purchased dust cover from Don at J8Ns, the cover is lined up with oiler & slotts, fits nice and tite on base however the 2spring clips with a smuch preasure as I could apply are still a quarter inch shy of the slots on the dist cap spoke to Don he indicated it should fit, the cap is new from NH shoud I force it even more?? or is ther something I am missing any help thanks ONTRICK
Bo
05-25-2003 05:49:32
 Re: Dust Cover ?? in reply to ONT RICK, 09-19-2002 07:02:36
I am having problem with dust cover going over spring that sits under rotor. It almost seems as if the distrib. sahft is too short but the cam retainer is there?? I did have to force the clips over the dist cap after dust cover was in place.
ONT RICK
09-19-2002 10:37:42
I have tried it without the rotar everthing seems to fit nicely except springs wont reach the slotts of the dist cap mabey I will try old cap or just blow out dust more often thanks again ONTRICK
don
09-19-2002 12:32:52
 Re: Re: Dust Cover ?? in reply to ONT RICK, 09-19-2002 10:37:42
I just tried one of the covers on my dist.,they will ony work IF you remove the rubber gasket.I think they made the rubber gasket too thick.You can ship it back if that don't work and I'll not sell them any longer. don
Jon in Mass
09-19-2002 08:20:55
I had trouble with mine after a tune up. I think my replacement condenser was slightly bigger than the original. I was able to get mine together after whacking the condenser a little to make it fit better in the dist. housing, also bending the spring bails down slightly made them fit.
Jon
ED-IL
09-19-2002 07:56:53
Pardon my ignorance, but what is a dust cover?
Evil Steve
09-19-2002 08:27:27
 Re: Re: Dust Cover ?? in reply to ED-IL, 09-19-2002 07:56:53
ED-
There is an afterthought piece of round moulded plastic (same diameter as dist cap) that fits just under your rotor (sidemount dist's) that acts to prevent dust/carbon from dropping into your dist and fowling points or getting into the bearing areas. It's cheap and a good idea (don b/New Holland).
ED-IL
09-19-2002 08:50:36
 Re: Re: Re: Dust Cover ?? in reply to Evil Steve, 09-19-2002 08:27:27
Oh....
Thanks steve
Evil Steve
09-19-2002 07:39:55
It should go together with no problem. Only thing I can think is your rotor is not correctly on the dist shaft.
