On the NAA's I've seen, and on the one I own, the light switch is on the right side (sort of mirroring where the starter switch is). But that doesn't really matter.Originally, the headlights were grounded to the frame and there was a single wire running from the left headlight, over the radiator and back along the right side of the hood where it was joined by a single wire from the right headlight. Most people install a "quick disconnect" (male and female connectors) in the wire there, so you can remove or raise the hood without having to cut the wires. But I digress. That wire runs to the switch, which contains a 20A fuse, and the other side of the switch connects to *either* the always-hot terminal on the terminal block or the terminal that's hot only when the ignition switch is on. (People here have offered differing opinions on which choice is best, and I don't know which was "original." The advantage of wiring to the not-always-hot terminal is that you can't leave the lights on accidentally (unless you also leave the ignition switch on accidentally); the disadvantage is -- some have said -- the ignition switch might not last as long if it has to handle the additional current load caused by the headlights. I played it safe and wired my light switch to the always-hot terminal.) If you have rear lights (running light and/or work/utility light), they worked the same way -- grounded to the frame with a single wire down inside the fender, along the rear axle (inside some sort of cloth sheath, originally; often inside a plastic sheath or fuel hose these days), over the rear end and under the draft control spring,along the side of the hydraulic and transmission housings, and from there to the switch. Now, regarding the grounding: Since I was rewiring the whole thing, I took Dell's and others' good advice and ran a separate pair of ground wires as well, because the chassis ground is often not as good today as it was 50 years ago. I ran them parallel to the headlight and taillight wires, and grounded them to the battery box/battery ground terminal. There's an 6V wiring diagram at the "Vintage Tractor Resource" that you might find useful; there's lots of other good NAA info at that site as well. Good luck, and if any of my rambling above isn't clear or doesn't match what you've got, don't hesitate to ask more.
