Won't start after oil change
Al
12-10-2000 09:08:07
I've just change the oil in my 9N which was running fine before. Now it chugs to start but will not turn over.
Sounds like low compression. Has a new carb,plugs,coil,oil filter.
Any suggestions???
Al
Keith 8N59448
12-10-2000 18:06:18
 Re: Won't start after oil change in reply to Al, 12-10-2000 09:08:07
Al,
Have you drained your carb? Sounds like water to me. Maybe throw some methyl alcohol in the tank.
=keith=
fasssttted
12-10-2000 22:20:14
 Re: Re: Won't start after oil change in reply to Keith 8N59448, 12-10-2000 18:06:18
could be mouse nest in tube between air cleaner and carb.
Mark *8N126975*
12-10-2000 16:43:34
What things did you do differently before it would not start. Was it just the oil change or did you also replace/overhaul the carb, plugs, etc.. How long since it last ran fine. After a cold front ? An oil change would have no influence on starting or running. I'm not trying to be a smart@$$, but a more detailed description of what all was done before and after would help a lot in helping with suggestions.
Al
12-10-2000 16:59:40
 Re: Re: Won't start after oil change in reply to Mark *8N126975*, 12-10-2000 16:43:34
This is how it went... I brought it into the garage to get it ready for winter.. Drained the oil from the bottom... drained the filter oil. and removed the filter... Waited a few days .. bought new oil, and filter and replaced. I did notice that the bolt was missing from the filter after starting once but put it back in and added oil to the filter canister. Still pops but doesn't want to start.
Mike OH
12-10-2000 12:24:20
I agree with the other comments you received. I'd just make sure your battery was fully charged and all connections were clean and tight. Then I'd check each plug, dry them off and try again. Let us know how you make out.
fast ed
12-10-2000 22:08:07
 Re: Re: Won't start after oil change in reply to Mike OH, 12-10-2000 12:24:20
had a mouse build a nest in tube between air cleaner and carb
stick
12-10-2000 10:48:28
Just changing the oil wont cause it not to start. Start with the basics, fuel, spark, compression.
al
12-10-2000 11:03:01
 Re: Re: Won't start after oil change in reply to stick, 12-10-2000 10:48:28
Well I know it's getting fuel cause it's running out the carb. I know it's getting spark cause it's chugging trying to start. The compression thing has be worried but it ran great before.
any other ideas?
Al
Truck
12-10-2000 11:21:48
 Re: Re: Re: Won't start after oil change in reply to al , 12-10-2000 11:03:01
Maybe you fouled your plugs by over choking?
Try a new set, or if you are cheeep like me, heat the tips up with a propane torch until they are a dull orange. This will burn off the fouling. Let them cool some before installing, and use neverseize on the threads. Don't get the never seize on the electrode or you will foul the plug again.
al
12-10-2000 11:26:51
 Re: Re: Re: Re: Won't start after oil change in reply to Truck, 12-10-2000 11:21:48
Sounds easy enough .. I'll give it a try and get back to you
