Sal, they come with either engine. As I understand it, the gas engine is the diesel reconfigured. i.e. The Ford engineers designed the diesel first then made the necessary changes to run it on gas. Susposedly this was the first time it was done that way. Previous models were done the other way around so their diesels were not as strong as they should have been. On the thousand series, this makes the gas engine like a tank, as I understand it. My 3000 is gas and is the easiest starting engine I own, though I do have a '47 8N that is real easy to start also. Have only had one problem starting it. That was when the points needed changing REAL BAD!! It went for easy starting to NOTHING, no cough, wheez, just cranked over, and over. Easy to fix though. My impression is that there are more diesels out there than gas. I almost bought a 2000 that had a front blade on it, but it was diesel and the guy wanted too much for me to take a chance on it. I have NO experence with diesels, but quite a bit on gas engines of all sizes. While I am replying let me tell you what I know about the differences between the 2000 and the 3000. First is the HP rating, BUT the engine is EXACTLY the same. What they did was use a lower RPM for the 2000 (1900RPM vice 2100RPM) for the specifications so it comes in at a lower HP - therefore it is the "bottom" of the line. The other difference is in the hydraulics. The 3000 has draft control in both forward AND reverse, the 2000 is just like the 8N, forward only. Then the 3000 as an optional flow control valve to control the lifting speed of the hitch. Also the 2000 was first delivered only with a 4-speed transmission, but I suspect that in later years they also had the 8-speed tranny as an option. I also remember seeing a 6-speed tranny in the service manual, but don't know which model it was for.
