Spin on Oil Filter Conversion
Ron (8n509270)
09-21-2002 04:58:05
Before I start, this is a working tractor.
The original oil filter can has been beat up pretty bad along with someone useing pliers on all the oil line connections.
While I am there replacing lines and cleaning everything up I was considering replacing the canister style filter with a spin on conversion.
Anyone have any experience with these? Good or Bad?
This is strictly for ease and conveniece.
Thanks
Ron (8n509270)
Dave Smith
09-22-2002 05:04:02
 Re: Spin on Oil Filter Conversion in reply to Ron (8n509270), 09-21-2002 04:58:05
Ron, Go to the thread I posted to John Fitzpatrick I posted below.
Dave <*)))><
Dave Smith
09-21-2002 13:57:58
Ron, look in the link below and phone them. You can get the kit for the Ford FL1 filter.
Dave <*)))><
John Fitzpatrick
09-21-2002 19:03:24
 Re: Re: Spin on Oil Filter Conversion in reply to Dave Smith, 09-21-2002 13:57:58
Dave-
If that's the same unit as I have on my SB Ford, the adapter threads onto the block where the original spin-on filter went and ports the oil inlet and outlet to female NPT sockets. From there you run hoses to a remote filter. Unless I'm missing something (wouldn't be the first time !) since the inlet/outlets on the tractor are some distance apart and there isn't anything to thread the adapter on, I don't think it would work.
However, you could buy a canister filter with bracket from them and adapt it's ports from NPT to tube fittings. Then you just find a convienient spot to mount the canister, bend some steel tube and connect it up.
Dave Smith
09-22-2002 05:01:31
 Re: Re: Re: Spin on Oil Filter Conversion in reply to John Fitzpatrick, 09-21-2002 19:03:24
third party image
This is a photo of the Perma Cool filter adapter I got from Jeg. It takes the FL1 filter the same as the engine. I got tired of hunting for filters for the M&W turbo on Big Blue when I changed oil. I modified the bracket to mount it. It does have 2 mounting holes on it. The oil comes from a fitting on the bell housing (the braided steel line) and goes on to the turbo after the filter. The M&W filters were costing me $12 and I figure it paid for itself after 3 oil changes. FL1 filters can be bought at Wall Mart a lot cheaper and I don't have to drive 25 miles to get them. Give Jag a phone call they can help you.
Dave <*)))><
Doh!! John Fitzpatrick
09-22-2002 08:33:48
 Re: Re: Re: Re: Spin on Oil Filter Conversion in reply to Dave Smith, 09-22-2002 05:01:31
Dave- I see it now-you screw the adapter onto the filter instead of the block-great idea!
John
Dave Smith
09-22-2002 09:49:53
 Re: Re: Re: Re: Re: Spin on Oil Filter Conversion in reply to Doh!! John Fitzpatrick, 09-22-2002 08:33:48
I think that is what Ron was looking for to replace the original filter canister. It would work good but not be original. Probably use a piece of Z bar stock to bolt to old filter bolt holes in the block and bolt the adapter to the other leg of the z bar.
Dave <*)))><
Jim in N.S.
09-21-2002 10:16:49
I installed one on an old dodge truck just last week. Bought it at a local auto supply dealer for $38 cdn. As Dell pointed out, you will have to make your own mounting bracket.
Ron/PA
09-21-2002 09:37:18
Ron, I have no experience with them but if you find out let me know, I would do it in a heart beat but I have never found a kit to do it. Thanx Ron
Dell (WA)
09-21-2002 09:33:45
Ron..... ...yeah, I considered it, just never got around tuitt. There are universal PH-8A spinon kits available but you need to make your own adaptor bracket to fit. Your call..... ...Dell
