Alternator idea
rick
09-21-2002 05:40:28
One of the things I don't like is the looks of an alternator on an old tractor. Has anyone investigated the idea of locating a small alternator, say from a motorcycle or something, that could be made to fit inside a gutted original generator. This would give the advantages of 12V and the look of originality.
ZANE
09-22-2002 07:28:07
 Re: alternator idea in reply to rick, 09-21-2002 05:40:28
The Japaneese are way ahead of us in the minature alternator field. (other fields too)
Kabota makes a generator that is on it's three cylinder diesels that is about three inches in diameter and is controled by an electronic voltage regulator located remotely from the alternator. I have never seen but one fail and it was the bearing worn out. I replaced the bearing and it's still going after at least 10 years of operation. Charges between 14 and 15 volts. Lots of amps too.
Steve T
09-21-2002 06:11:14
Rick, I am about half ways through restoring a 1940 IHC "A" and decided to make it a 12 volt setup, and didnt like the looks of an alternator. What Im doing is using a 12 volt generator off of a 1964 Ford Falcon car. I had to build brackets of course to make it fit, but sure looks good and only a purist could tell that it wasnt original. I also have a 1945 2N with a 6 volt set up and am going to leave it that way. Steve T
Ron/PA
09-21-2002 06:24:12
 Re: Re: alternator idea in reply to Steve T, 09-21-2002 06:11:14
Steve, if you want to stay with a generator, we have a guy here in our area that will convert your original generator to 12 volts then the purists will have to look at the battery to tell.
Ron
