Order Ford 8N Parts Online
8N OVERHEATING
8N?9N?
09-21-2002 07:57:55
Ok guys I need some help 8N overheats has new raditor. Has thermostat and it isnt sticking tractor will run about 30 min with brushhog or box blade on then gets hot. engine has been rebuilt with new water pump timing is set correctly anyone have any ideas it is driving me nuts. I am going to take the rad to be flow tested just to be sure.
Fast Ed Ohio
09-25-2002 23:00:44
 Re: 8N OVERHEATING in reply to 8N?9N?, 09-21-2002 07:57:55
I had the same problem, thought it was overheating. It had to much fluid in the radiator, if you look close at the neck of the radiator it has a small male fitting that needs a hose to direct the expanded fluid to the ground and not onto ( Not so hot ) engine.
Dave OH
09-21-2002 22:13:28
Your radiator may be new but think about the water jackets in the engine being pluged after 50 yrs. of maybe hard water. Back flush the block if other posts do not work. You will be supprised at what comes out.
Dave OH
Rusty
09-21-2002 09:56:05
A bad head gasket can force water out. Then the tractor will overheat. Fill it with water and run it with the cap off. Look for gases exiting the radiator.
Al (NC)
09-21-2002 08:31:47
Make sure your thermostat in not installed backwards. If in doubt, remove it for a test.
8N?9N?
09-21-2002 08:28:04
Got to looking and the fan shroud is missing bet that is the problem as the air is going everywhere except through the raditor if someone thinks different let me know
Rusty
09-21-2002 09:51:20
 Re: Re: 8N OVERHEATING in reply to 8N?9N?, 09-21-2002 08:28:04
Got one without a shroud. No problem. Will get around to installing one, maybe.
8N?9N?
09-21-2002 10:34:09
 Re: Re: Re: 8N OVERHEATING in reply to Rusty, 09-21-2002 09:51:20
Just put a new headgasket on it head isnt warped and I did retoque it. Went to my mom's to pick up the 9N rad to put on it guess someone stole it because it is gone. I did find a fan shroud that I think will fit the new rad on this tractor doesnt look as heavy as the one that came off of the 9N so I may have to get another one.
