Dirty pictures / Radiator hygene
Allen in Oregon
09-21-2002 19:56:27
The 51 8n I just got had a bad head gasket. I relaced it and it would over heat within a few minutes. Now I know why! I spent most of the day rodding out the radiator and resoldering. What a difference it made! It runs cool as a cucumber now.
Fast Ed Ohio
09-22-2002 22:36:38
 Re: Dirty pictures / Radiator hygene in reply to Allen in Oregon, 09-21-2002 19:56:27
A plugged radiator has ruined a lot of good engines over the years .
Jerry (AL)
09-22-2002 09:16:45
Don't know that I have ever seen one quite that bad.
Larrys8n
09-22-2002 04:33:27
Allen,what type of flux and solder did you use? Larrys8n
Allen in oregon
09-22-2002 09:05:05
 Re: Re: Dirty pictures / Radiator hygene in reply to Larrys8n, 09-22-2002 04:33:27
Larry, I used plumbers solder and paste flux. It was NOT the newer leads free stuff. We can still buy the real stuff here as long as you don't use it for plumbing. Allen
Dave OH
09-21-2002 20:28:09
Yes, I guess that would have stopped the flow. Thanks for posting the pictures they are worth a thousand words. I think some people may have questioned my advise about plugged radiators. Dave OH
Allen In Oregon
09-21-2002 20:33:55
 Re: Re: Dirty pictures / Radiator hygene in reply to Dave OH, 09-21-2002 20:28:09
Dave, I don't know what your radiator advice was but I think after seeing the insides of this one everybody with an older radiator should have them serviced or replaced. I am going to check my other two right away. Allen (;^)
Willy-N
09-21-2002 21:15:46
 Re: Re: Re: Dirty pictures / Radiator hygene in reply to Allen In Oregon, 09-21-2002 20:33:55
Works good to blast water inside them and wash them out once and a while to help keep them clean too. Mark H.
Mark Ok
09-21-2002 21:35:55
 Re: Re: Re: Re: Dirty pictures / Radiator hygene in reply to Willy-N, 09-21-2002 21:15:46
Look to like to much stop leak. But hey it worked.All stopped up.
Dave OH
09-22-2002 10:57:28
 Re: Re: Re: Re: Re: Dirty pictures / Radiator hygene in reply to Mark Ok, 09-21-2002 21:35:55
You should have seen some of the "Cold" water pumps they opened up at work. Calcium and Lime deposits are worse in a "Hot" water system.
Some well water is almost crunchy.
Dave OH
