Concur that the most likely scenario is that the previous owner just threw in a twelve volt battery and called that a conversion. Two ways to go from here: If the twelve volt battery is a new good brand battery it might be worth doing a correct twelve volt conversion now. Although I am generally against converting to fix troubles you can buy an alternator for about what a six volt battery is going to cost you. I did a twelve volt conversion on a 2n that got burned over in the Maudlow fire only because it turned out cheaper than fixing the six volt system. On the other hand, the priceist part is the generator and if it makes voltage--also might want to try to motor it since if it motors it will generate; see IT FO 4 manual or post again--then you may want to stay six volt. Either way you will need to make coil voltage conform to system voltage. Assuming a six volt coil on a six volt system use the ballast resistor. On a twelve volt system with a six volt coil use the ballast resistor and a standard [blue streak] RU 100 dropping resitor in series [like flashlight batteries]. If any of this isn't clear post again or e mail me since like Dell I have "been there; done that; got a t shirt" on twelve volt conversions. Cleaning up some body else's twelve volt mess is no fun but as long as you keep the board up to date somebody will ride to the rescue. Your mileage may vary
