2n clutch wont let me shift until its ready
russ
09-23-2002 12:45:38
i have a 2n that when i push in the clutch i cant get it in or out of gear for sometimes up to 2-3 min.i have the rpm's bearly idling .whats da deal?also,the rear pto shaft is very wobbly but i already put in a new bearing .any ideas
Levi (WA)
09-23-2002 21:16:28
 Re: 2n clutch wont let me shift until its ready in reply to russ, 09-23-2002 12:45:38
Mine does the same thing, is your clutch grabby when you let the pedal up, if it is then it has oil on it and the disc is sticking to the flywheel...its very common, but most think its rusted to the flywheel which isn't as common as some think.
Willy-N
09-23-2002 12:58:19
Two things come to mind clutch out of adjustment or it is coming apart and draging on the flywheel. The second problem might be a bent PTO Shaft. Mark H.
