Blocking the Clutch Pedal down
Sam (Mo.)
12-10-2000 16:46:49
third party image
Our temperature here is supposed to drop an incredible 50 degrees in the next 24 hours (I hate that). So, this afternoon I decided to block down the clutch pedals on my two 8N's in the barn so the clutch plates won't freeze to the flywheels. Rather than cut a stick to fit below the dash, I decided that something about 5" long would fit O.K. between the clutch pedal and a bolt head on the rear radius rod bracket.
Fortunately, I found some things around here that are JUST the right size and shape to do the job - as you can see in the photo!
Jim K
12-10-2000 17:07:52
 Re: Blocking the Clutch Pedal down in reply to Sam (Mo.), 12-10-2000 16:46:49
You know what they say,(reuse recycle)
Paul
12-11-2000 03:19:22
 Re: Re: Blocking the Clutch Pedal down in reply to Jim K, 12-10-2000 17:07:52
In michigan that can would be worth 10 cents. Is that a full can or empty? I would use a full one that way in the spring before it hits 45 degrees you will have a nice treat.
