Well, with all that junk in there you have to drain the hyd fluid first and flush all the junk out (kerosene works well - just get it all out when finished). Kinda doubt it got into your pump since it happened so quickly and your pump shut off right away. Frankly though, it'll be hard to flush all the stuff that's in the nooks and crannies with the pump still in there and it'll eventually circulate and get into your pump. So, if it was me, I'd pull the pump, clean, clean, clean in the housing, and insepct my pump/replace orings while I was at it. It's really a gamble. There is a video available on this and other sites (I haven't watched it so I don't know how good it is). If you aren't in a hurry, you might wanna get one and see what's involved. It isn't hard and only took me a day to rebuild mine and the parts are readily available. Dennis N Tx put a large magnet in the bottom of his housing to catch shavings. Next time I'm in there I might do the same. If you go the "drain and flush only" way, you might want to do that as well.
