Jubilee steering leak
Alan
09-26-2002 06:34:57
I have my Jubilee sheet metal off and decided to check the steering gear fluid....I removed the filler plug and put a little dipstick down to check the level....I did not get any indication of any fluid in the box....I figured it just wouldn't go dry without a problem so I decided to filler up and see what happens....Sure enough overnight both steering gear arms were leaking...My question is .....can I just remove the arms and replace the seals and the packing or is it more complicated then that....Also....Could some damage have been done running it almost dry...I did not seem to have any steering problems before....As always any opinions greatly appreciated....Alan
Al (NC)
09-26-2002 11:49:43
 Re: Jubilee steering leak in reply to Alan, 09-26-2002 06:34:57
That's pretty standard. Pack it with grease
Mike OH
09-26-2002 07:44:02
Alan- I found the same condtion to be true with my Jubilee. I replaced the seals etc, and filled with the recommended oil and all has been well. I did however do a complete tear down and replaced the top bearing.
Some recommend using grease instead of oil and that's what I did on my 8N. Used corn head grease in it and think it is a better way to go. Think it gives better lubrication to the top bearing and is thick enough not to want to run out.
bob(nc)
09-26-2002 19:41:54
 Re: Re: Jubilee steering leak in reply to Mike OH, 09-26-2002 07:44:02
I have the same problem with oil leaking from the steering box. Could you please explain what "Corn head grease" is?
Mike OH
09-27-2002 07:36:56
 Re: Re: Re: Jubilee steering leak in reply to bob(nc), 09-26-2002 19:41:54
Bob-
Corn head grease is used in corn harvesters / combines. It is a softer or thinner grease than regular grease and seems to work well in cold weather. I believe it can be bought at any of the larger tractor dealers. I got mine at the local John Deere dealer.
