Sickle Bar Mower
russMo
09-26-2002 13:45:35
The photo adds have a McCormick model 75, 7Ft. sickle bar mower for sale. Can anyone tell me if it will operate with the 2N?
Thanks
Paul R.
09-27-2002 08:00:25
 Re: Sickle Bar Mower in reply to russMo, 09-26-2002 13:45:35
The all-knowing Dell is right, you can make it fit, but there are better choices. Look for a Ford 515 mower, or as a second choice, a Ford 505. Both are good, work perfectly on the 3-point, lift up with the hitch, need no hydraulics, etc. Older Ferguson or Dearborn mowers work good too, but can be a b**ch to install or remove.
The mowers with a hydraulic lift were built for those disadvantaged tractors not equiped with a 3-point hitch. Leave 'em for the Deere's and the Farmall's.
Dell (WA)
09-26-2002 19:53:37
Russ..... .....its a trail-behind sickle bar mower and uses a remote hydraulic cylinder to lift the bar. And while you could figger out how make your N pull a trailer, and how to make a remote hydraulic cylinder opperate outta your N's internal hydraulics, if'n you were REALLY DESPERATE..... .BUT WHY?????
Good cat-1 3-point sicklebar mowers are readily available for comparable price. And they fit..... ....Dell
