Funk 6 cylinder engine ID help please
Randy
09-27-2002 04:54:53
I have a 2N Funk conversion. Numbers on the side of the engine are - K18311. What year and engine is this? Thank you for any help.
D. R. White MN
09-27-2002 15:21:15
 Re: Funk 6 cylinder engine ID help please in reply to Randy, 09-27-2002 04:54:53
Randy, That number may be a casting lot number. Is the motor a flat head or over head valve? If it's a flat head look under the dist. where the block meets the oil pan you should see a number like 7HA-6010-B or on the head the number OHA-6050. This would be a H-series motor 226 ci. 95 hp. They where also used in pickup trucks. Hope this helps. Dave.
Randy
09-27-2002 16:13:26
 Re: Re: Funk 6 cylinder engine ID help please in reply to D. R. White MN, 09-27-2002 15:21:15
Dave, thank you very much. I'll go look for numbers first thing in the morning.
