AMP GAUGE +OR
ONT RICK
09-27-2002 11:19:33
I have late model 8n 6volt the amp gauge that I bought has + - marked next to each terminal, wire diagram shows lead from solenoid to gauge, + or - side?? then it goes from + or - side?? to terminal block does it matter which side I use to connect amp gauge to solenoid or teminal block ?? both solinoid & teminal block are neg correct? any help would be appreciated oh! got my front emblam today from j8ns thanks Don & eveyone else for your help ONTRICK
Dell (WA)
09-27-2002 12:18:41
 Re: AMP GAUGE +OR - ? in reply to ONT RICK, 09-27-2002 11:19:33
Rick..... ...just install it. you won't hurt it. If it reads the wrong way, just swap wires on back of ammeter. and it'll read the way you want. Traditionally, ammeter reads (+) when charging the battery with engine running. Positive or Negative ground, still gotta charge the battery..... ....Dell
