Condensation in the rear case, please help..
Rick
09-28-2002 07:53:34
I am the proud owner of a 1949 Ford red belly and the problem I am having is water in the rear case where the hydrolic pump is. I can pull out the dipstick and see that there is water in the oil. I changed the oil back in the spring when I first got the tractor home but it has water in it again. Is there something I can do to keep the water out and will it be of concern in the winter months comming up? I keep the tractor under a shed that I built. Thanks for all your help...Rick
Mountainman
09-28-2002 11:20:41
 Re: Condensation in the rear case, please help.. in reply to Rick, 09-28-2002 07:53:34
Like bg said.
Also avoid spraying water where the rod inside the big spring in the top link goes into the housing.
Condensation could also be a problem.
hth
Mountainman...CA
bg
09-28-2002 07:57:10
Use a new gasket on the transmission cover and a new rubber boot on the shifter and a new gasket on the filler cap.
