I've got a short somewhere!
Ole Bob
10-01-2002 03:46:33
Since spring when I bought this 50' 8-N I have been through 3 battries had the starter in the shop twice(replaced bushings 1st time, 2nd time they coudn't find anything wrong)Yesterday when I went to start the tractor it turned over good,after about 3 spins I remembered that I had not opened the gas valve,then when I went to start it all I got was that sickening buzz from the solenoid BTW that is new too, also new thumb sized cables.Where would you all sugest I go from here. Thank's, this is a great site,Bob, Bedford Co.Va
Dell (WA)
10-01-2002 06:38:06
 Re: I've got a short somewhere! in reply to Ole Bob, 10-01-2002 03:46:33
Bob..... ....if'n ya been thru 3 batteries since spring, what makes you so certain your starting problem is the starter motor INSTEAD OF the generator?..... ...Dell
Phil (NJ-AZ-SK)
10-01-2002 05:33:35
Ole Bob, I would make sure that the Bat Ground Cable is connected to "Bare" Metal Contact with the Frame. The Bolt itself is not a good conductor..
If the starter is the problem it should have the same problem when directly Jumpered.. Tractor out of Gear (should never be left in gear) and jumper cables, one to Frame and touch the other to the Starter side of the selenoid (starter post)... Starter should crank (note:do not push Starter Button) If ignition key is "on" Tractor should Start (can jumper with 12V this Way).
Hope This Helps
Soundguy
10-01-2002 05:47:03
 Re: Re: I've got a short somewhere! in reply to Phil (NJ-AZ-SK), 10-01-2002 05:33:35
He also might check both his ignition and starter switches for bad contacts, or corrosion based shorts ( to ground, or contact to contact ).
Jumper wire with aligator clips are good for this sort of thig.
Soundguy
DavidO
10-01-2002 07:55:23
 Re: Re: Re: I've got a short somewhere! in reply to Soundguy, 10-01-2002 05:47:03
"that sickening buzz from the solenoid" This is the normal indication (sound) that the starter is not getting sufficient voltage to operate properly. (Dead Battery) I agree with Dell. Check your charging system for proper operation and repair as needed.
