Hyd Oil Suction Hose for Wagner Loader
Popster (MD)
10-01-2002 08:54:33
I finally installed the replacement spool valve on my 8N Wagner loader. A couple of questions:
1. I rigged a piece of automotive heater hose as part of the return line in the hydraulic system. Is this acceptable?
2. The archieves suggested using 30 w non-detergent oil or hydraulic oil 042. I know Wal-Mart sells two gallon jugs of hydraulic oil? How do you tell grade?
Thanks for any help!
bg
10-01-2002 09:24:56
 Re: Hyd Oil Suction Hose for Wagner Loader in reply to Popster (MD), 10-01-2002 08:54:33
If it's a non-pressurized return hose, you may get by with it. I'd feel better if you used a piece of hydraulic hose, because if a hose ruptures, spraying hot hydraulic oil is dangerous.
Read the label on the oil jug. It will tell you the grade and rating and conformation specs. I don't know what Wagner specifies, but I'd try to find out first. Just because someone used 30 wt doesn't mean it's the best choice. It may be, but if I didn't know(and I don't)I'd be finding out.
