Order Ford 8N Parts Online
8n original rims
rick
10-01-2002 13:26:33
I am looking to buy a replacement set of rims for my 8n. The previous owner put the new 6 bolt type on that you can see through. Is there any advice as to where I can get the original type or if there is a reason to stay away from them? Someone told me that the old type collects rainwater in them and causes rust through. I am restoring it to original and plan to garage it.
Thanks
bg
10-02-2002 09:56:02
 Re: 8n original rims in reply to rick, 10-01-2002 13:26:33
I contacted a wheel manufacturer about making some of these and I haven't gotten back to them with a rim for them to use as a model. Until I strike oil in the back yard or win the lottery so I can get these made, your best bet is watch ebay or check the boneyards. I have one extra rim, but it doesn't quite match the others I have. It may have been an early 9n or 2N rim. It looks pretty much the same on the outside but the dimensions are a little different inside.
steve19438
10-02-2002 07:37:53
the ford dealer i deal with calls the original 8N rims "BOX RIMS"????
Dell (WA)
10-01-2002 16:24:25
Rick..... ....original 8N rear rims are commonly called "hat section" rims and are scarce as hens teeth because most of 'em are cancer victims of leaky Calcium Choloride watered innertubes for additional weight for traction. Rainwater has nothing to do with it. Sorry, I don't know of any source for original rear rims..... ....Dell
rick
10-01-2002 17:58:05
 Re: Re: 8n original rims in reply to Dell (WA), 10-01-2002 16:24:25
I am not referring to the flat or old "hat" style, but rather what you see on most 8n's. Unfortunately, my 8n has an old rim like I have on my '53 Jubilee and also a new type rim that attaches with 6 bolts. Kind of looks like a large version of the front wheels.
