Photo Adds
R.M. In AL.
10-02-2002 20:41:23
I look at the photo adds most every day.I often see the word "Rockshaft" .Whats a rockshaft.Also when the add says TA needs repair what does that mean. Thanks...R.M. In AL.
Levi (WA)
10-02-2002 23:20:35
 Re: Photo Adds in reply to R.M. In AL., 10-02-2002 20:41:23
What bg and Willy says PLUS rockshafts are in different places on the different makes of tractors but they are generally the shaft that comes directly out of a hydraulic system/pump etc. that the first arm will be attached to. hope that makes sense??
bg
10-02-2002 21:09:47
TA means Torque Amplifier as used in International(Farmall) tractors. They oftern need repair.
Willy-N
10-02-2002 20:46:22
The Rock Shaft goes between the upper Lift Arms in the Hydraulic Top Plate under the seat. Not sure what TA means you would think they could spell it out in the add? Trans Axle?? Mark H.
