Battery door change
Allen in Oregon
10-02-2002 22:20:18
I want to put the battery / gas door from a rusted out 2n hood onto my script hood with out a door. Is there a source for the rivets that the hinges are fastened with? Thanks, Allen (;^)
Cliff (VA)
10-03-2002 18:17:02
 Re: Battery door change in reply to Allen in Oregon, 10-02-2002 22:20:18
McMaster Carr sells rivets by the box. Look under "fasteners"
Link did not take
10-03-2002 18:18:57
 Re: Re: Battery door change in reply to Cliff (VA), 10-03-2002 18:17:02
The link to McMaster Carr is
www.mcmaster.com
Link did not take
10-03-2002 18:18:50
www.mcmaster.com
Dave Todd
10-03-2002 15:37:36
I ended up using a little special bolt that I bought from Bob Drake Reproductions, out in Grants Pass Oregon. They sell reproduction Ford Parts. I would imagine Dennis Carpenter has them too. They are a special little bolt with a rivet head, and are made to replace the rivets in the old headlight mounting brackets. From the outside, you will never know they are bolts. They seem to be the right size and everything. The Part Number is A-1345-R 1932 - 1934 Headlight Mounting Kit. The URL is www.bobdrake.com
Hope this helps!!!
Dave
good observation . . . Dell (WA)
10-03-2002 23:41:31
 Re: Re: Battery door change in reply to Dave Todd, 10-03-2002 15:37:36
Bob Drake Ford Repros in Grant Pass Oregon, well known and respected Ford hotrod body parts supplier on left coast..... ....Dell
don b
10-03-2002 10:35:16
Read your parts book very careful about the rivets.I'm pretty sure you can get them at the local hardware. don
