Sherman step down??????
Allen in Oregon
10-03-2002 08:41:30
You guys tell me if I am wrong but doesn't the tag on this tranny say step up? Some one could be VERY dissapointed buying this one if the tag is what I think it is.
don b
10-04-2002 06:38:52
 Re: Sherman step down?????? in reply to Allen in Oregon, 10-03-2002 08:41:30
That is a step up tranny.The step down tranny has the same shifter lever as the step up-step down tranny.It is also painted a dull gold color if it has original paint.I am talking about the Sherman tranny. don
Willy-N to DON B.
10-04-2002 07:02:39
 Re: Re: Sherman step down?????? in reply to don b, 10-04-2002 06:38:52
Don; When did Ford use a straite cut gear on the input shaft on the Transmission? Mark H.
don b
10-04-2002 14:36:56
 Re: Re: Re: Sherman step down?????? in reply to Willy-N to DON B., 10-04-2002 07:02:39
I think all 9ns had the straight cut gear on the input shaft 9n7017A.They changed on the 2n and maybe on the late 9ns,not sure.I think I know why you are asking.....Sherman over drive trannys? don
Willy-N
10-04-2002 15:08:36
 Re: Re: Re: Re: Sherman step down?????? in reply to don b, 10-04-2002 14:36:56
Don; People have asked befor about that gear. In the book it shows a Helical cut gear for 1939 to 52 input shaft??? Is the book wrong? Useing Shermans in the older and newer tractors is why I am asking. Mark H.
don b
10-05-2002 07:52:36
 Re: Re: Re: Re: Re: Sherman step down?????? in reply to Willy-N, 10-04-2002 15:08:36
Well, if you are looking in the MPC 39-53,yes that is sorta mis-leading.My 41 parts book shows the straight gear.When looking at the "52" version of the 39-53 MPC,one needs to remember that when they give "year" dates,all that means is, that part "can" be used on those years of tractors,not necessarlly what was the original part.Having said this,COMMON SENSE TELLS ONE THAT YOU CAN'T MIX STRAIGHT AND HELICAL GEARS as you know.This also applies to a lot of other parts in the MPC. don
Dave OH
10-03-2002 13:26:48
Also, correct me if I am wrong. But you had better know if you have a heilcal or straight, shaft drive in your tractor. It is not universal, as a change was made. I beleive, in the early 50's ?
Dave OH
Willy-N
10-03-2002 15:43:44
 Re: Re: Sherman step down?????? in reply to Dave OH, 10-03-2002 13:26:48
Dave; I have yet to see a straite cut gear in the input shaft. I have heard about them on this site and have taken them apart back to 9N 1942, I know they have straite cut gears in the 9Ns and 2Ns in the transmission. The book says the helical gear was used from 39 to 52 on the Ns and there might have been a 39 9N that used it but I would like to see a picture of the straite cut input shaft if some one has one. Thanks, Mark H.
Willy-N
10-03-2002 09:46:28
Yes they would and the step down is worth more and the step up is worth 1/3 of that price. They will be bummed when they put it in and find out. I sold a step up once but it turned out to be a step down and the guy was upset but I was too because it sold for a lot less then it was worth! Mark
Allen in Oregon
10-03-2002 08:49:24
third party image
