Winter Oil Wt.
Sal
10-05-2002 13:52:42
I'd be interested in knowing what other's use for a winter wt. oil.
I am in upstate NY, Syracuse area.
I have been using a 10-30 Valvoline, Would it be better to go to a 5-30? My 51 & 52 engines are in good repair.
...and what are the thoughts on a detergent oil vs. a non-detergent oil does a rebuild make a difference on what to use?
Thanks.
- Sal
don t - 9n180179
10-06-2002 01:33:03
 Re: Winter Oil Wt. in reply to Sal, 10-05-2002 13:52:42
I live in N. central Il.
Summer straight 30wt. Winter 10-30.
Mine has low comp. but starts w/o a problem.
dave#1
10-05-2002 15:26:07
Hey sal,
Well, to answer your question-
I use 10w-40 in everything I own, year around,sometimes I use the cheap stuff and sometimes I use the good stuff ! seems to work just fine.
hope this helps
later,dave
Dell (WA)
10-05-2002 14:31:23
Sal..... ...I'd continue to use the Valvoline 10-30 oil.
The ONLY REASON to use non-detergent oil in any engine is you're TOO CHEAP to drain and throw away oil that you've only used for about 1/2 hr of break-in time on a $1500 rebuilt engine. USE THE GOOD STUFF..... ...Dell
