A message for the 6 Volt Advocates
Ron (8n509270)
10-09-2002 18:12:20
Just a quick note about easy starting 6 volt systems. A few weeks ago I did a complete tune up, new wiring harness along with new battery cables.
I started my ole N up this afternoon and of course it started right up. The only thing different, I had forgot to disengage the pto. Attached to it was my 6 foot finishing mower.
Who'd a thunk it?? Start up, under load, on push of the button, and at only 500 rpms.
Jimmyjack
10-09-2002 23:04:48
 Re: A message for the 6 Volt Advocates in reply to Ron (8n509270), 10-09-2002 18:12:20
When everything on the tractor is the way it is supposed to be 6 volt is wonderful. Ground is probably the most important maintainance item, and use a heavy enough cable.
Willy-N
10-09-2002 19:40:16
A long time ago I used a 6 Volt System to turn the engine over to load a tractor on a trailor! Had to shift to 1st gear to go up the ramps but it did it none stop! Mark H.
Rusty 2N
10-09-2002 18:47:26
Yep, I'll keep my 6V.
Soundguy
10-10-2002 06:08:27
 Re: Re: A message for the 6 Volt Advocates in reply to Rusty 2N, 10-09-2002 18:47:26
The 6v 'frog eye' lights on my 8n provide much more light than the built in 12v jobs on my NH 1920... I turned them both on in the barn last night, and there is no comparison... the 12v lights are about as bright as (1) of my N's 6v lights.
I realize there is a wattage difference... but it goes to show that 6v can do the job!
Soundguy
DavidO
10-10-2002 09:16:29
 Re: Re: Re: A message for the 6 Volt Advocates in reply to Soundguy, 10-10-2002 06:08:27
How "bright" your lights are is a function of power NOT voltage.
phil fenner
10-10-2002 13:18:48
 Re: Re: Re: Re: A message for the 6 Volt Advocates in reply to DavidO, 10-10-2002 09:16:29
But remember, Power=voltageXcurrent so voltage has a direct effect, everything else being constant such as resistance. Another way of expressing power in terms of voltage is:
P=VxV/R
Light brightness however has a lot of other variables other than power, related to the reflector/glass efficacy and bulb resistance.
