Picture Test
Bama8N
10-10-2002 13:31:00
third party image
OK! Uploading to Bobduck was easy enough. Now if the picture will post this will be a snap. If it does post it will be the toy hauler I bought just before my surgery. Here goes.
DickTN
10-10-2002 13:48:38
 Re: Picture Test in reply to Bama8N, 10-10-2002 13:31:00
Your picture came through O.K. PLEASE remember to put a jack or block under the back of the trailer when loading. If you don't, the stress will transfer to the trailer hitch. If that comes unhitched at a crucial time, you might well need some more surgery. BE SAFE! DickTN
heybusdriver
10-10-2002 23:31:46
 Re: Re: Picture Test in reply to DickTN, 10-10-2002 13:48:38
Good point, also another point to remember is to be sure the ramps are fastened securely to the trailer and the welds are in good shape. Once I rented a trailer that the weld on the ramp broke just as my tractor wheel entered the deck, luckily had enough forward motion to continue to roll on to the deck. Stan
jim
10-10-2002 16:32:19
If you are considering adding jacks on the rear corners, I purchased two implement jacks at TSC and welded one on each corner. When loading or unloading , just swivel the jacks into place and youve eliminated a potential disaster.
ED-IL
10-10-2002 13:47:55
Wow! Big Trailer!
By the looks of it, I am guessing hooking it up is what caused the surgery?
Bama8N
10-10-2002 13:41:51
Wow! That was easy enough. Only problem now is I don't know how to get back to that picture if I wanted to send it again. Do you just upload each time you want to post? Can you build a file? Who is "Bobduck"? Every time I learn something new it opens up 15 new questions. I think I'm going to blow up. Sure is fun though.
David Ransom
10-10-2002 21:36:12
 Re: Re: Picture Test in reply to Bama8N, 10-10-2002 13:41:51
Bobduck posts frequently on another YT board, Tractor Tales. I believe the picture only remains for a day or two, after which time you would need to upload it again if you wanted to post it again. You could get the picture's URL right here by right-clicking the picture and clicking properties. Pictures are not normally removed from the YT galleries, but in all except Kountry Life they are automatically ensmalled.
