Rib tires vs. Truck tires
Paul 8N
12-13-2000 03:13:31
I have a 8N with a front end loader. Would I have better control with rib tires? I currently have retro-fit truck tires on it and every little rut seems to try and turn wheel into direction it wants to go. They are a wide tire, I'm not worried about what it does to the land I am preparing to build on. Thanks for your input.
Lonnie
01-27-2002 16:37:36
 Re: Rib tires vs. Truck tires in reply to Paul 8N, 12-13-2000 03:13:31
with a front loader ribed tires are easer to steer
rides on center rib less rubber on the ground
Dell (WA)
12-13-2000 08:08:33
Paul..... .really sounds to me that you might have some "loose" parts in the front end and may deed to consider "rebuilding" the front end.
You might need to think about the negative effects of a frontend loader on a tractor that really wasn't built or designed for frontend loader work. N's are really not that great of front end loader machines, but if thats all you got..... then rung what ya brung.....
I would also seriously consider the effect of putting in more front tire air pressure...say 50 psi. It won't hurt your tire or tractor and might make the turning eazier. I wouldn't recommend "rib" tires, the're really only good for plowing. Pays yer moneys, and take your choices..... ...Dell
Jim WI
12-13-2000 11:06:32
 Re: Re: Rib tires vs. Truck tires in reply to Dell (WA), 12-13-2000 08:08:33
Make sure not to exceed the maximum air pressure marked on the sidewall of the truck tires!
yep.....Dell (WA)
12-13-2000 12:19:33
 Re: Re: Re: Rib tires vs. Truck tires in reply to Jim WI, 12-13-2000 11:06:32
and always go thru the highway patrol weight stations and don't exceed the GVW and don't exceed the speed limit and don't drive on the highway without a SMV triangle and...and ..... .all of which are ticketable offenses..... and most of all, don't exceed the molded pressure on the truck tire sidewalls (my truck tires say 80 psi for 3500 lbs)..... . May Henry protect us all from our own stupidity ..... .Dell
Jim WI
12-15-2000 11:07:32
 Re: Re: Re: Re: Rib tires vs. Truck tires in reply to yep.....Dell (WA), 12-13-2000 12:19:33
Didn't mean to sound critical... Sorry.
But:
1) Never can tell how much (or how little) someone asking a question knows about the subject.
2) My truck tires say 35psi. (Admittedly it's a light truck but it's still a truck.)
The two together could result in someone using too much pressure for a tire.
MikeC
12-13-2000 03:45:04
Here is a thought...
I have a 9N with the narrow ribbed tires on the front. In snow I get pretty good turning response, they seem to dig in better. Tears the daylights out of the grass in the summer though.
My neighbor has an 8N with wider car type tires on the front. It seems much easier on the lawn, but in the snow he has much more trouble with the front end sliding.
I also have a Dearborn loader on the front, and the narrow ribbed tires seem to handle it just fine.
Good Luck!
