Adjustable Tappets
Al-n-Mo.
10-13-2002 18:17:25
I'm putting my 9n back together and bought adjustable tappets. My question is, what keeps the adjuster bolt from turning after you set the valve lash without a lock nut?????
Thanks, Al
Levi (WA)
10-13-2002 22:04:53
 Re: Adjustable Tappets in reply to Al-n-Mo., 10-13-2002 18:17:25
The adjuster on the tappet is very tight and will not turn on its own, when ajusting them it takes a good amount of force to turn them. You will need the tool to to adjust them.
AL-n-MO.
10-18-2002 19:24:16
 Re: Re: Adjustable Tappets in reply to Levi (WA), 10-13-2002 22:04:53
Thanks, that was going to be my next question about them being hard to turn. I just got the wrenches so I should have her back together and running this weekend.
Thanks again, Al
Rick H. Ga.
10-13-2002 18:52:59
Hi Al. I wondered the same thing when I rebuilt my 8N a couple of years ago. In fact, one older tractor mechanic, who had been around a while (from the old school), told me the adjustable tappets would not stay adjusted. He suggested I use the old style non-adjustable type. I asked that same question on this board and got advice that the adjustable tappets would stay adjusted. I have been using my 8N with the adjustable tappets for about two years and the engine is extremely quiet and I have not had to re-adjust the tappets. And, besides, if I did need to adjust them it would be easy and would not require dissembling the engine and valve train like the non-adjustable tappet adjustment would require. HTH Rick H. Ga.
