O/T Winterize a Diesel Engine
Quickdraw
10-15-2002 12:13:28
Is it O.K. to "fog", spray engine storage oil down the intake of a diesel engine the same way you would do a gasoline engine? Is there a better way to store the engine for the winter? It will be left outdoors all winter. Thanks in advance, Doug.
Dave Smith
10-16-2002 05:04:55
 Re: O/T Winterize a Diesel Engine in reply to Quickdraw, 10-15-2002 12:13:28
I put my Johnson Outboard 25 fishing motor away for the winter yesterday. I sprayed marine foging oil in it while cranking it over. The darned thing started and ran on it. I had drained the carb. I had to disable the ignition by pulling the safety clip to keep it from running.
Dave <*)))><
Al
10-15-2002 17:36:42
fogging oil down a diesel could make it start is it is flamable.
