PTO lever pops out.
Rickstir
10-17-2002 07:37:16
Annoying little problem. Hope it is not serious. When running my Jubilee with PTO engaged, especially when first starting out, the lever will pop back and disengage the PTO. Sometimes it happens if I mow into some tall fescue, like it is caused by the load. After the first 15 mins. or so it seems to straighten itself out. I hope this is not a signal of a bigger problem starting. Anybody got any ideas? Thanks as always for your help.
Don, Luling LA
10-17-2002 17:01:04
 Re: PTO lever pops out. in reply to Rickstir, 10-17-2002 07:37:16
Don't myself remember the exact problem it is but my 860 has done it for years, I just use a rubber bungie cord to hold it ingaged until I one day tear the tractor down to see what the culprit is.This might also work for you until you can do the same.
Tom 8N396936
10-17-2002 09:46:30
Check the archives. Same thing happens to my 8N and I posted, got some great responses but can't remeber them (good memory just short). If I remember right it is most likely something minor a spring on an indent?
HTH
tom
