Sherman over/under
photofarmer
10-19-2002 08:25:26
I have a 52 8N with a sherman over and under (combination?) that worked great when I bought it 3-4 years ago-now I can't get the sherman lever to go back for the high range(?). It will pot out and slide forward-any ideas?
Willy-N
10-19-2002 17:47:39
 Re: Sherman over/under in reply to photofarmer, 10-19-2002 08:25:26
You will have to split it to find out but it sounds like the cap that holds the spring and detent ball (on the shifter) has come loose and poped out. It is probley laying in the bottom of the bell housing. If you can find the parts down there in the grease they are a 1/4 X 1 inch plus spring, 1/4 inch ball bearing and a threaded cap to hold them in. They go in above the rod shifter on top of the sherman housing. Mark H.
