Order Ford 9N Parts Online
Do Original VW Bug Wheels Fit 9N/2N Fronts?
Arthur Brestlin
10-20-2002 04:28:27
While walking past an old bug without hub caps, it occurred to me that the bolt pattern closely resembles that of the early N's. Has anyone ever tried to measure them for this?
Ford Man
10-20-2002 19:44:24
 Re: Do Original VW Bug Wheels Fit 9N/2N Fronts? in reply to Arthur Brestlin, 10-20-2002 04:28:27
My 2N had hubs and wheels from a '37 Ford automobile complete with brake drums ! I tried a set of original 2N wheels but they would not fit on the hubs . Also tried VW wheels and they would not fit MY hubs but I think I saw a set on a 2N in a book .
Ford Man
bg
10-20-2002 15:53:18
AS mentioned below, the late 30's wheels will fit. The Bug wheels resemble the od Ford wheels, but I don't know the bolt-pattern spacing. There's lots of old farm trailers around here made from old Ford axles that have that type wheel mounted.
Jet9N
10-20-2002 07:43:29
No they don't, but it seems to me some time ago
I saw where some one had changed the whole hub with the bearings. Check the archives.
HTH
Jet
ZANE
10-20-2002 06:53:02
I have had the same idea about the VW wheel pattern maybe being the same as the 9N/2N. I can't tell you if it is or isn't.
I can tell you though that Henry used the same bolt pattern on the 38 Ford cars and trucks as the 9N/2N Tractors.
Zane
tw
10-20-2002 14:12:40
 Re: Re: Do Original VW Bug Wheels Fit 9N/2N Fronts? in reply to ZANE, 10-20-2002 06:53:02
Henry used the same bolt pattern on the 36, 37, 38, and 39 Ford vehicles.
