Extendable Lower Lift Arms for Cat I?
Rochester (WA)
10-22-2002 00:26:52
Does anyone know if they make extendable lower lift arms for Cat I 3 point hitches like the Cat II versions? I sure would like to reduce my hitch up times on those larger implements without all the cussin and fussin that I usually encounter. My neighbor's Case IH and JD are a breeze to hitch up with--why not create the same setup for Cat I's too?
Dell (WA)
10-22-2002 13:03:39
 Re: Extendable Lower Lift Arms for Cat I? in reply to Rochester (WA), 10-22-2002 00:26:52
Probably has to do with the weight of the Cat-2 implement vs the weight of the Cat-1 implement. I've never had any trouble hooking up my cat-1's. Some use a prybar and bigger hammer, but I've never had the need for my brushog, rear scoop, disk harrow, lift platform, haybale grinder, boompole..... ..... Dell
