Order Ford 8N Parts Online
Do all 8n's have an inverse oiler on the intake manifold??
8nguy
10-24-2002 10:57:53
third party image
ours does but im wondering who else does
john
10-24-2002 12:24:16
 Re: Do all 8n's have an inverse oiler on the intake manifold?? in reply to 8nguy, 10-24-2002 10:57:53
I' ve seen many n series with the stall cock left in permanetly. All you had to do is slip on the vac hose, turn the lever and go to milking.
Dell (WA)
10-24-2002 11:12:35
8Nguy..... .....would you believe that is a "vacuum" port for when the power goes out and you need to run your milker for your dairy cows? You do know that dairy milkers are vacuum operated, don't you?..... ...respectfully, Dell
Barnstormer
10-24-2002 17:09:05
 Re: Re: Do all 8n's have an inverse oiler on the intake manifold?? in reply to Dell (WA), 10-24-2002 11:12:35
Marv Baumann has a video tape for sale and there is a piece on the N being used for the milker in the event there was a power failure. Check out Marv's new web site.
oops, forgot....marvinbauman.com...is his web site
10-24-2002 17:11:18
 Re: Re: Re: Do all 8n's have an inverse oiler on the intake manifold?? in reply to Barnstormer, 10-24-2002 17:09:05
Barnstormer
ok, ok double oops...I'm tired - that is marvinbaumann.com
10-24-2002 17:22:36
 Re: Re: Re: Re: Do all 8n's have an inverse oiler on the intake manifold?? in reply to oops, forgot....marvinbauman.com...is his web site, 10-24-2002 17:11:18
ya gotts to get al the leters rite or it don wuk.
I was a fairly good speller in grade school but I work for a company that wanted to streamline spelling (before desktops) because it saved money in key strokes.
I continue .....
10-24-2002 14:37:39
to be amazed at your knowledge. Where did you first learn of this tidbit?
Rob
what i meant was....
10-24-2002 11:28:14
we had it working the milking operation....way b4 1 was born!!!
...Pardon me?
10-24-2002 11:26:15
Jim.UT.........well I can call it a day now!
10-24-2002 11:15:45
I just learned something new! Thanks, Dell!
