Order Ford 8N Parts Online
Rear main seal 8N
Sam
10-25-2002 05:49:41
I am going to replace the clutch on my 8N and was wondering if the rear engine seal and the front transmission seal can be changed while the tractor is split? I have a oil leak but not sure if it's engine or transmission until I split the tractor. So my question is can the rear main on the engine be replaced without dropping the crankshaft or oil pan?
Thank You
ZANE
10-25-2002 08:06:35
 Re: Rear main seal 8N in reply to Sam, 10-25-2002 05:49:41
The oil pan must be removed to do anything to the rear main or the front main seals.
Unless you want to remove the crankshaft don’t even think about trying to remove the upper main bearing seal on the N engine.
There is a better way to fix it if it really needs fixing. First the rear main bearing itself must be in good condition or trying to fix the rear seal is just a practice in futility.
If the rear main bearing is OK you should first remove the hood tank and the front axle and radiator etc. This will give you ample room to drop the pan. This will save much wailing and knashing of teeth! Obtain an original rear main bearing seal kit for the Ferguson TO 20 engine. This consists of a bottom seal similar to the one used on the N engine and a big ball of cotton roping. Cotton Roping is what a big cotton thread looks like before it is twisted in the cotton mill.
Using a soft welding rod of about 5/32” start packing the cotton roping into the upper seal. Don’t try to remove any of the original upper seal but pack all of the roping you can get into the upper seal slot. The old seal will be compacted and fill any void that is in the upper seal.
Replace the lower half of the seal with an original N seal. Don’t worry about the different colors on the ends of the seal if it matters I haven’t been able to find out what it is in the last 40 years.
Sam
10-25-2002 17:33:22
 Re: Re: Rear main seal 8N in reply to ZANE, 10-25-2002 08:06:35
A great big thank you for the imformation.
Sam.
TimK
10-25-2002 07:35:56
The trans seal can be easily replaced by removing the four bolts holding the retainer housing on the main shaft and pulling it out. The engine rear main can't be replaced without dropping the crank. Now, I believe Zane once said that a packing from a TO-35 could be used to replace the main seal without dropping the crank, so why don't you contact him for details. My $.02
