Darrel (ok) and BG
8nguy
10-25-2002 08:35:23
so after hearing the sound of My N what do you think i should do??
It sounds a little better when outside. I recorded that inside the shed!!
I bought a new mic and if i can get the laptop to work ill try one from outside....
Darrel(ok)
10-26-2002 00:49:40
 Re: Darrel (ok) and BG in reply to 8nguy, 10-25-2002 08:35:23
Hi Darren,
I wasn't laughing at your tractor, I was laughing at the quality of the sound recording. After the initial startup, its hard to tell whats going on. I give you an A+ for effort. Its more than I could do. It sounds like your six volt system starts up on the 3rd or 4th crank, that sounds good to me. Your dad should know how the tractor is supposed to sound, its been around since you were a little kid. I don't think there's anything wrong with it.
Now that cold weather is settling into your neck of the woods, I would suggest that you give all your spark plugs a good cleaning. Cold weather is hard on spark plugs.
Darrel.
bg
10-25-2002 09:23:14
Tune-up, valve adjustment and muffler.
ok...thanks bg!!
10-25-2002 09:29:44
 Re: Re: Darrel (ok) and BG in reply to bg, 10-25-2002 09:23:14
ok...dad said the other day the prob might be the generator or alternator not gettin enough juice...
are the listed stuff cheap or $$$$$$$$????
send any info you might have to bni@execulink.com...thats my dads email addy...just ask or tell what might be needed!!
