Different rear tires
photofarmer
10-25-2002 10:35:23
I have a 52N with two different brands of ag tires on the rear-supposed to be the same size but one is slightly wider with slightly different tread. They were new when I bought the tractor 3 years ago. Will this hurt the differential and should I buy a matching tire when I work on the rim/brakes and replace the rear seal which has a slight leak?
REMMo
10-25-2002 11:02:33
 Re: Different rear tires in reply to photofarmer, 10-25-2002 10:35:23
The difference in size will have no ill effects on the tractor at all. REM
