Marvel Mystery Oil
Arthur Brestlin
12-14-2000 14:55:09
I have read several articles in The Newsletter over the last several years. Most of them sounded positive as I recall. Does anyone on this discussion board have any firsthand experiences with this product? I am considering using it with both my motor oil and gasoline as a cylinder top lubricant! Any and all replys are greatly appreciated! This forum is GREAT! Thanks to all who contribute!
Redbelly1
12-15-2000 04:25:18
 Re: Marvel Mystery Oil in reply to Arthur Brestlin, 12-14-2000 14:55:09
I still use it.
I know it'll stop lifters from sticking if there's not a mechanical problem.
ZANE
12-14-2000 18:58:48
I am sold on Marvel mystery oil. Here is something that was sent to me by someone on this board when I was giving my true testominial once a while back. Food for thought. I'm still sold on it!!!!!
MARVEL OIL -- MYSTERY OIL MATERIAL SAFETY DATA SHEET
NSN: 915000F003957
Manufacturer's CAGE: 95015 Part No. Indicator: B Part Number/Trade Name: MYSTERY OIL ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === General Information
Company's Name: MARVEL OIL COMPANY INC Company's Street: 331 N MAIN ST Company's City: PORT CHESTER Company's State: NY Company's Country: US Company's Zip Code: 10573-3305 Company's Emerg Ph #: 914-937-4000 Company's Info Ph #: 914-937-4000 Record No. For Safety Entry: 002 Tot Safety Entries This Stk#: 002 Status: FE Date MSDS Prepared: 16FEB93 Safety Data Review Date: 31MAY95 Preparer's Company: MARVEL OIL COMPANY INC Preparer's St Or P. O. Box: 331 N MAIN ST Preparer's City: PORT CHESTER Preparer's State: NY Preparer's Zip Code: 10573-3305 MSDS Serial Number: BXKDX ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Ingredients/Identity Information
Proprietary: NO Ingredient: MINERAL OIL, PETROLEUM DISTILLATES, SOLVENT-REFINED HEAVY
NAPHTHENIC DISTILLATE
Ingredient Sequence Number: 01 Percent: <75 NIOSH (RTECS) Number: PY8040000 CAS Number: 64741-96-4 ----- ----- ----- ----- ----- ----- -
Proprietary: NO Ingredient: MINERAL OIL, PETROLEUM DISTILLATES, SOLVENT-DEWAXED HEAVY
NAPHTHENIC
Ingredient Sequence Number: 02 Percent: <75 NIOSH (RTECS) Number: PY8038000 CAS Number: 64742-63-8 ----- ----- ----- ----- ----- ----- -
Proprietary: NO Ingredient: STODDARD SOLVENT (PETROLEUM DISTILLATE), MINERAL SPIRITS
Ingredient Sequence Number: 03 Percent: <30 NIOSH (RTECS) Number: WJ8925000 CAS Number: 8052-41-3 OSHA PEL: 500 PPM ACGIH TLV: 100 PPM Other Recommended Limit: 525 MG/CUM ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Physical/Chemical Characteristics
Appearance And Odor: REDDISH VISCOUS LIQUID W/HYDROCARBON ODOR.
Boiling Point: 341.6F Vapor Pressure (MM Hg/70 F): 5 Specific Gravity: 0.83 Solubility In Water: UNSOLUBLE pH: 6.3 ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Fire and Explosion Hazard Data
Flash Point: 174F Lower Explosive Limit: 0.9 Upper Explosive Limit: 7 Extinguishing Media: FOAM, DRY CHEMICAL, CO2
Special Fire Fighting Proc: USE WATER TO COOL EXPOSED CONTAINERS. IF
LEAK/SPILL HASN'T IGNITED, USE WATER TO DISPERSE VAPORS & PROVIDE
PROTECTION FOR MEN ATTEMPTING TO STOP A LEAK.(SUPP)
Unusual Fire And Expl Hazrds: VAPORS ARE >THAN AIR & MAY TRAVEL ALONG
GROUND/BE MOVED BY VENTILATION & IGNITE BY HEAT/PILOT LIGHTS/OTHER IGNITION
SOURECES DISTANT FROM HANDLING POINT.
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Reactivity Data
Stability: YES Cond To Avoid (Stability): HEAT, SPARKS, FLAME
Materials To Avoid: STRONG OXIDANTS
Hazardous Decomp Products: CO2, CO
Hazardous Poly Occur: NO Conditions To Avoid (Poly): CONTACT W/SKIN.
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Health Hazard Data
LD50-LC50 Mixture: ORAL LD50 (RAT): 5 G/KG Route Of Entry - Inhalation: NO Route Of Entry - Skin: NO Route Of Entry - Ingestion: NO Health Haz Acute And Chronic: SKIN: PROLONGED/REPEATED CONTACT W/PRODUCT
TENDS TO REMOVE SKIN OILS, POSSIBLY LEADING TO IRRITATION & DERMATITIS.
EYES: MAY CAUSE IRRITATION. PRODUCT HAS A LOW ORDER OF ACUTE ORAL & DERMAL
TOXICITY, BUT MINUTE AMOUNTS ASPIRATED INTO THE LUNGS DURING INGESTION/
VOMITING MAY CAUSE MILD TO SEVERE PULMONARY INJURY.
Carcinogenicity - NTP: NO Carcinogenicity - IARC: NO Carcinogenicity - OSHA: NO Explanation Carcinogenicity: NONE
Signs/Symptoms Of Overexp: IRRITATION
Emergency/First Aid Proc: EYES: FLUSH W/CLEAR WATER FOR 15 MINS. SKIN: IF
INJECTED INTO/UNDER/ANY PART OF BODY, REGARDLESS OF APPEARANCE OF THE
WOUND/SIZE, PERSON SHOULD BE EVALUATED IMMEDIATELY BY PHYSICIAN AS A
SURGICAL EMERGENCY. EVEN THOUGH INITIAL SYMPTOMS FROM HIGH PRESSURE
INJECTION MAY BE MINIMAL/ABSENT, EARLY SURGICAL TREATMENT W/IN FIRST FEW
HOURS MAY REDUCE THE ULTIMATE EXTENT OF INJURY. (SEE SUPP)
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Precautions for Safe Handling and Use
Steps If Matl Released/Spill: RECOVER FREE PRODUCT. ADD SAND/EARTH/OTHER
SUITABLE ABSORBENT TO AREA. MINIMIZE SKIN CONTACT. KEEP OUT OF SEWERS &
WATERCOURSES BY DIKING/IMPOUNDING.
Waste Disposal Method: PREFERRED METHOD IS INCINERATION. DISPOSE OF IAW/
FEDERAL, STATE & LOCAL REGULATIONS.
Precautions-Handling/Storing: KEEP CONTAINERS CLOSED WHEN NOT IN USE.
DON'T STORE NEAR HEAT, SPARKS, FLAME/STRONG OXIDANTS.
Other Precautions: AVOID PROLONGED/REPEATED CONTACT W/SKIN.
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Control Measures
Respiratory Protection: USE SUPPLIED AIR RESPIRATORY PROTECTION IN
CONFINED/ENCLOSED SPACES, IF NEEDED.
Ventilation: LOCAL EXHAUST: TO CAPTURE VAPOR/MIST/FUMES IF NECESSARY.
MECHANICAL (GENERAL): ACCEPTABLE.
Protective Gloves: HYDROCARBON RESISTANT Eye Protection: SPLASH GOGGLES Other Protective Equipment: APRON, IMPERVIOUS CLOTHING IF NEEDED.
Suppl. Safety & Health Data: SPECIAL FIRE CONT'D: WATER SPRAY MAY BE USED
TO FLUSH SPILL AWAY FROM EXPOSURES. MINIMIZE BREATHING OF GASES/VAPORS/
FUMES/DECOMPOSTION PRODUCTS. HEALTH HAZARDS CONT'D: INHALATION: REMOVE TO
FRESH AIR. GIVE CPR/OXYGEN IF NEEDED. INGESTION: DON'T INDUCE VOMITING.
OBTAIN MEDICAL ATTENTION IN ALL CASES.
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Transportation Data
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Disposal Data
===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== ===== === Label Data
Label Required: YES Label Status: G Common Name: MYSTERY OIL Special Hazard Precautions: SKIN: PROLONGED/REPEATED CONTACT W/PRODUCT
VOMITING MAY CAUSE MILD TO SEVERE PULMONARY INJURY. IRRITATION
Label Name: MARVEL OIL COMPANY INC Label Street: 331 N MAIN ST Label City: PORT CHESTER Label State: NY Label Zip Code: 10573-3305 Label Country: US Label Emergency Number: 914-937-4000
Nolan
12-14-2000 16:46:07
Like many of us, I've used it, with good results.
Want to see something interesting though, look at the MSDS for it. It's almost pure kerosene with some solvents thrown in.
homeboy
12-14-2000 15:38:06
Arthur Please go to the archives and hit search type in Marvel Mystry Oil for many opinions on this subject. Very interesting. Merry Christmas and God bless. Homeboy
pat
12-14-2000 15:14:18
We used it in our tractors, trucks and small engines back on the farm and tt works like advertised. I still use it today.
