Order Ford 8N Parts Online
1952--8n engine a mess
9n141
10-29-2002 17:55:45
How much can a crank be turned, it is already 30 thou.? Nice straight 8n . Any suggestions?? Also @ what ser.# did they change to slower reverse? THANKS. BURT.
9n141
10-30-2002 16:34:33
 Re: 1952--8n engine a mess in reply to 9n141, 10-29-2002 17:55:45
Thanks for all the info.,BURT
Dell (WA)
10-29-2002 23:57:18
Burt..... ...you can turn crankshaft journals to the greatest oversized bearing shell available. My Ford Master Parts Catalog lists 0.020 as max oversize available. Guess what? You can't fit Ford bearings can you? I believe that I have seen 0.040 bearing shells. Your machine shop should have a catalog of available bearing sizes.
It is unclear at what s/n the last of 52 8N's got a slower reverse gear and if'n I had to guess, it would probably be s/n 500,000+. Its not listed in my Ford MPC..... .....Dell
denton
10-30-2002 10:20:09
 Re: Re: 1952--8n engine a mess in reply to Dell (WA), 10-29-2002 23:57:18
Mine is 502419 and has the reduced reverse idler gear in it.
Soundguy
10-30-2002 06:55:05
My 52 8n sn 504580 does not appear to have a 'swelled' tranny area.. castings look straight.. and reverse is quite a ride!
Soundguy
Mike OH
10-30-2002 09:09:19
 Re: Re: Re: 1952--8n engine a mess in reply to Soundguy, 10-30-2002 06:55:05
My 52 8N S/N 515797 does have the bump out at the transmission and reverse is still faster than my 53 Jubilee which I thought had the same transmission. I usually only use reverse at an idle and sometime have to slip the clutch for better control.
