It is nice to start a tractor without wondering if it will start or not. Have the 841 with Elenco front end back from the shop and hard at it (when time allows) degreasing it and fixing minor seals and leaks. Rebuilding power steering pump ,replacing hydraulic lines, rear brake seals, and replacing the seal for the hydraulic pump. Also need to figure out why the left side jumps and rolls a bit while scooting down the road in 4th. Front left tire seems out of round and rear tires are new and seem to be seated ok. Me thinking front tire is the culprit. Need advice on the steering: she wants to meander left and right too and not straight. Ideas or suggestions about that? Not much play in the steering wheel.
Boy she sounds good and strong with new motor in it. Rebuilt motor, tranny, clutch, rear end, cooling, lift, and exhaust. New head, oil and water pumps too. Runs really fine and starts on a dime. What a monster though....without any sheetmetal on it, she looks like a brute with that front end. Will take some pics soon and post. Got to run. 9N'er
