Charging wow's
phil (so il)
11-01-2002 19:45:10
n'gurus,
have to say this appears to be a great site.im a proud owner of a 48 8n and she is a workin machine,problem is my pal has a 49 and is experiancing charging probs.(he is stuck in the dark ages and refuses to get wired to the internet)anyway told him i would ask of the vast aray of knowledgable people here to see where we need to start to diagnose his prob.it has been converted to 12 volt system.
gman
11-02-2002 19:59:57
 Re: charging wow's in reply to phil (so il), 11-01-2002 19:45:10
if it is not a strapped alt and it is charging but the bat drains when switch is turned off you have backfeed to alt that is draining the batt you can get a safety shut off they use on stationary power units put it in an oil line and run your wire from alt to batt thru 2 of the terminals this will shut the back flow off when switch is off got mine at auto zone about15.00 bucks
bj/8n/mt
11-02-2002 07:57:56
Part of the joy of twelve volt conversions is there are so many ways to do it. Some of them even work.
Without more information about how the conversion was done and what the trouble is Dell's suggestion below is as good as any--get the alternator checked.
What does the ammeter read runing and at rest? Does the battery hold a charge? Is there a current drain somewhere? Is it a one wire alternator that isn't getting reved enough to excite it? So many possibilities so little information.
Your mileage may vary
bg
11-01-2002 20:04:18
Without knowing how the conversion was done, it's tough to say, but my first thought is that the alternator is not being "excited" at high enough rpm to start the charging cycle. Dell will probably chime in shortly and provide the fix.
Dell (WA)
11-01-2002 21:43:27
 Re: Re: charging wow's in reply to bg, 11-01-2002 20:04:18
Phill..... ...what bg sez..... ..and..... .
Take the 12 volt alternator into any autoparts store and have a "freebie" alternator check. Thats where I'd start. The commonly used Delco 10-SI 12 volt alternator has built-in voltage regulator. Then assuming your 12 volt battery is good and charged, make certain all your big battery cable connections are clean, bright, and tight..... .....Dell
phil(so il)
11-01-2002 21:49:16
 Re: Re: Re: charging wow's in reply to Dell (WA), 11-01-2002 21:43:27
would a check at the battery while running w/a volt ohm meter tell me if the alt is good?
not necessarily . . . Dell (WA)
11-01-2002 22:04:18
 Re: Re: Re: Re: charging wow's in reply to phil(so il), 11-01-2002 21:49:16
Phil..... ...ya said "charging problems", what is so difficult about understanding "freebie" alternator check? ..... .....respectfully, Dell
