Draft/position
Rod
11-03-2002 16:32:36
What does the DRAFT/POSITION lever do?
i was told.......
11-04-2002 05:37:47
 Re: draft/position in reply to Rod, 11-03-2002 16:32:36
i was told it switched between the front hyd and rear hyd...still have yet to see that happen lol!!
Jim
11-04-2002 05:05:48
This link may help.
ZANE
11-03-2002 18:03:42
When the little mode lever is up it is in position mode. This allows the lift arms to be set at a given heitht.
When the little lever is down it is in draft mode. Draft mode is used with ground engaging equipment such as a plow.
See the archives for information about draft.
