Order Ford 8N Parts Online
Oil leaking from 52 8n brake drum
pete
11-04-2002 03:26:39
is this something that can be fixed by a shade tree mechanic or does it need to go to a shop. what is the procedure? there is a two inch nut at the end of the axle.
Don (NC)
11-04-2002 06:35:36
 Re: oil leaking from 52 8n brake drum in reply to pete, 11-04-2002 03:26:39
Do an archive search for "rear seals" and you will find hundreds of posts about this subject. To get to archives, if you're new at it, on the top of the main forum page, click on "View Archives", then click on "keyword search", and type in rear seals (without quotes). Good luck.
