Fan-radiator
8ndexta-ger
11-04-2002 10:32:56
I use the mighty 8N in the bush a lot, on rough ground and in very tight quarters. I just did it again. Gently bumped a tree with the front of the hood. Once again, I put the fan through the rad. This is probably the 4th or 5th time its happened.
How much clearance is normally between the fan and rad?
Fast Ed Ohio
11-04-2002 23:56:36
 Re: fan-radiator in reply to 8ndexta-ger, 11-04-2002 10:32:56
Well, I can get my finger between the fan and radiator, never tryed it with the tractor running , like to keep what fingers I got.
Soundguy
11-04-2002 12:13:09
That radiator is just a tad bit cheaper than a bumper.. might be time to buy / build one.
Soundguy
Actually (ED-IL)
11-04-2002 12:47:53
 Re: Re: fan-radiator in reply to Soundguy, 11-04-2002 12:13:09
My new radiator cost about twice what my new bumper cost.
It was a lot easier to install too!
Dell (WA)
11-04-2002 11:00:56
Man..... ..getts yer eyeballs checked before the tractor police pulls yer license.
'Course, ya can always put a frontbumper on, 'atts whatt the're made fer, clumbsey drivers. (grin)
Usually there is about 1/2" clearance between radiator and fanblades.
Check your frontaxle kingpin (under radiator) jackitt up and wiggle the axle stuff around. Driving over ruff ground gonnna bump alotta stuff together..... ...Dell
Willy-N
11-04-2002 10:38:14
Might be a good time for a bumper/brush gaurd on the front end. I can take a look at mine and see how far it is away. Funny that one has been in there 50+ years and not a scratch? My truck is on the 3 rd one and nothing has hit it? Mark H.
simonmeridew
11-04-2002 18:21:59
 Re: Re: fan-radiator in reply to Willy-N, 11-04-2002 10:38:14
Probably 20 years ago I was working the 8N in the woodlot and a stick poked up into the fan and forced a blade forward into the radiator. Stopped the fan dead, imbedded in the fins. Water and antifreeze squirtin out everywhere. I got the radiator off--the hardest part was getting the fan blade out of the fins--and I started straightening fins and tubes. Some of the tubes were cut off completely, probably 3 or 4 of them, some just had holes in them. I started cutting fins away from the broken tubes, enough to work on the tubes; then I crimped the bad tubes over, and started soldering them off. Probably 1/2 hour later I had a leak free radiator. Cooling capacity may be reduced some but I never notice and never overheat. You can still see where the blade sliced into the core; it looks like someone took an axe to it.
BTW, brass (or copper) radiators solder nice, don't think it would work on aluminum car radiators.
simonmeridew
Willy-N
11-04-2002 18:42:44
 Re: Re: Re: fan-radiator in reply to simonmeridew, 11-04-2002 18:21:59
I dropped a wrench once and nicked the radiator on my 69 Camarao after that when I work on them I put cardboard in front of them!! I just put a drop of soder on it and fixed it. Mark H.
misusing tractor 8Ndexta Ger
11-05-2002 06:09:05
 Re: Re: Re: Re: fan-radiator in reply to Willy-N, 11-04-2002 18:42:44
Henry Ford never intended this tractor to do what it gets used for in the bush (fall and winter). Firewood and logging in rocky country. The general plan is to drive the 8N to where the wood is and then hopefully get the load close enough to where the Dexta can reach it with a chain if (when) it gets stuck.
I also don't like the look of a bumper on this tractor (spoils the lines!:-)) But repairing and replacing radiators is a pain too.
My fan is seems to he a quarter inch from the rad.
Maybe I just need a new (unbent) fan. Thanks for the input. I love this little tractor. 8Ndexta Ger
