2N Died and Won't Restart
Ron
11-04-2002 14:51:21
Have a 2N with 6V, front mount distributor system. I was out cutting grass this afternoon and after about 45 minutes the tractor just died. No warning before it stopped. It's now 2 hours later and the tractor won't start. I'm aware of the common problem with a bad coil that after about an hour of operation that the coil heats up and the tractor dies. But I thought that after the coil cooled down, it's normal function returned and the tractor would then start. Am I mistaken about this? Is it worth it to try a new coil? I have had no starting problems prior to this occurrence. Any advice would be much appreciated.
Ron
DavidO
11-05-2002 05:06:57
 Re: 2N Died and Won't Restart in reply to Ron, 11-04-2002 14:51:21
Quickest way to determine what is wrong is to do some voltage measurements. Turn on the key and measure the voltage at the top of the coil. You should see battery voltage if the points are open and about 3.5 volts if the points are closed. If the voltage is zero, you have a problem between the battery and the coil (switch, resistor, wire). If the voltages check as described above, check to see if you have a spark at the plugs. If not, you have a problem with the coil or distributor (points, condensor, rotor, cap). If you have a good spark at the plugs, then I would look for a fuel problem. You are right, the common symptom for a shorted coil is that it will "heal" itself when it cools, but that is not 100%. It can fail and not "heal" when it cools so make no assumptions, make measurements.
ED-IL-46-2N
11-04-2002 17:05:24
Hey - you probably flooded it after it shut down. Let it sit with the fuel shut off for a while and try it.
BOB
11-04-2002 16:15:56
Ron i was cutting grass with my 9n then it died without a putter. had to take trailer and load it in the field,what a pain in the A#$%. as it turned out the points where shot. make sure you have fire at plugs hope this helps post back
Danny in CO
11-04-2002 15:02:16
Ron,
Do you have spark at the plugs? Could it be a fuel problem? It no spark, it could be a broken wire or connection or slipped points.
Danny
